Electrian gone AWOL | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Electrian gone AWOL in the UK Electrical Forum area at ElectriciansForums.net
J
Jamesmf
Hi,
I've had an extension built and the 2nd fix electrical is all done and all the electrician needs to do is test and issue cert. Problem is I can't get hold of him.
I have tried asking other electricians if they will test but all so far have refused as they didn't do the design and install. Its all that's holding up my completion cert. from the council.
Other than track him down, what can I do? I have photos of 1st fix and the design, which I guess is no good.
Cheers
James
Trev it's like an episode of murder she wrote!
@ the op how long since you spoke to the electrician, was anything said the last time you saw him, have you any contact details for him, if you have his company name then usually a quick internet search should find him.
I'm guessing it was the quickest test you have ever performed lol
Got that funeral place tested today Glenn, crikey it was weird.
First EICR that I ever did with no 1s or 2s, there wasn't even that many 3s so little chance of any remedial work :(
hope you didn't wake geordie. :smilielol5::smilielol5::smilielol5:
No mate, I've done quicker. I was there a good 3.5/4 hours and had a good old rummage into everything. Just because there were stiffs lying around there's no excuse not to be thorough :)
True, it's probably not much different to spending your time in here!
yes mate sorry for delay I've just had my tea, I will pm you right now young man! :grin:
And I knew you would suss it out, the sign of a good fault finder!
Reply to Electrian gone AWOL in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Recommended Sponsor News
Hi everyone,
