Surely a safety inspection of an unvented hot water system should include checking the functions of any safety thermo-stat and over pressure relief valve.
a failure of these devices could lead to an explosion.
Agreed, but the problem with testing over-pressure relief valves is that they very frequently never seal properly again... resulting in a permanent pressure leak hence forward... until they finally get replaced years later.
Sounds like your boiler might be on the fritz! While I'm no electrician myself, a quick search for "boiler repair Surrey" online should point you in the right direction of some qualified folks.
