Electric car chargers | Page 5 | on ElectriciansForums
Discuss Electric car chargers in the UK Electrical Forum area at ElectriciansForums.net
pirate
Supporter
Glasgow
Just wondered if anyone has seen the advert for the new Fiat 500E...
If you read the small print at the bottom it says you can charge it enough in a few minutes to do 30 miles, using an 84kw charger...probably not a domestic installation then...
However, on a 13A plug it only takes 19 hours to charge...
There's a few questions in my mind about this, but please say what you think.
I witnessed the ship car transporter from Japan hitting the jetty at Sheerness, it was moving at about 2mph, but demolished approximately 500M of jetty.
I'm not sure of the point you are trying to make with your example, a ship can be affected by a number of external influences that can provide motion or continued motion long after it's main power is removed it can take several miles to bring it to a stop even with the props running hard astern
Reply to Electric car chargers in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
I think it is my old system.. The electricians were from Qmerit that works with GM, they came to the house looked it over before agreeing to do...
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
