Electric Car Charging | Page 2 | on ElectriciansForums
Discuss Electric Car Charging in the Electric Vehicles Advice Forum area at ElectriciansForums.net
The only way to safely use this vehicle is to use the Charger supplied with or for it.
If the only charger / charging lead available is only for a 3 phase supply and you don't have access to that at home or work then this van is no good for you.
If there is a charger or charging lead for 240volt , then you need that.
I've already seen the picture. Can you confirm what the inverter is intended to do, ie. What is it feeding?
I'm not sure and I cant get technical data from anyone.
I believe it's a single to 3 phase inverter supplying the converter in original picks to charge batterys for the van
Looks like a company called Nidec bought Ansaldo - I would try contacting them.
Reply to Electric Car Charging in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Depending on the specific battery you (intend to) buy, you might be able to just do Monster alternator -> LiFePo4 battery. The BMS for the fancy...
