Electric cooker 2500 watts to plug into normal spain plug socket? | on ElectriciansForums
Guest viewing is limited
Discuss Electric cooker 2500 watts to plug into normal spain plug socket? in the UK Electrical Forum area at ElectriciansForums.net
Valencia
Hi All,
We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good standard.
Due to some miscommunication with the electrician however, he forgot to create a separate circuit for the electric cooker.
Looking at the cooker, it is an old one, the Teka HWE 490 ME, The oven has a total power of 2550 watts, with a grill power of 1400 watts.
You can see in the photos where the oven power cable was connected to the old circuit (the white wiring, the other black wire goes up to be ignitition for a gas hob, now not required as we just use a lighter).
My question is, can I just connect the power cable from this old cooker to a normal plug (see other attached photo where I found a power cable that I think I could use) and just plug into a normal plug socket in the kitchen to power the cooker?
Also running on the kitchen circuit are a lightbulb, a modern fridge freezer and modern gas boiler (that needs electricity to power the display unit for it) also a kettle and toaster used occasionally. The kitchen is about 10 metres away from the main circuit board in the house.
So, would it be safe to use the cooker like this, or would it be too much for the circuit (I don't want to damage our new electric installation).
Any advice would be very much appreciated,
Trav
  • [ElectriciansForums.net] Electric cooker 2500 watts to plug into normal spain plug socket?
no is the answer , you need a separate circuit for it .
Thank you for fast response.
The reason I asked is because I had read elsewhere online:
"Electric ovens have a wattage rating that tells you how much power they use. For ovens under 3000 watts, it is perfectly acceptable to power them using a regular 13 amp plug and socket. In most cases (but not all, every home is different), this should mean any plug socket is fair game."
So I wanted to check here, so even though my oven is 2500 watts, it still needs the separate circuit in your opinion?
Your oven is 3950 watts, oven plus grill. The quote you have posted is probably for a UK installation where the 13amp plug is fused, unlike Spanish plugs.
The cock block is already overheating as can be seen on the phase wire connection, you need a competent electrician to have a look, there also seems to be some cross connections in that block.
Reply to Electric cooker 2500 watts to plug into normal spain plug socket? in the UK Electrical Forum area at ElectriciansForums.net
I have replaced the back box for a 35mm one, and it all has refitted more comfortably. I'll get the electrician to check it out when fitting the...
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
Recommended Sponsor News
Hi everyone,
