Electric Cooker advice | on ElectriciansForums
Discuss Electric Cooker advice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
ajtaylor09
I have a Bosh cooker to install on the weekend and was wondering on any advice you could provide me on installing it, tips and tricks etc...?
Am i right to think i need 2.5mm T&E cable for this job also what rating should the amp be in the ccu?
Previous oven was installed via a 13amp plug
Sorry, in work and a bit stressed out so previous info was pants.
Its
Electrical connection rating (W)2350Current (A)16Voltage (V)220-240
If you've got a socket as pasrt of the cooker switch, you will need to upgrade the cable and breaker - potential for drawing 26 amps which would be outside the the range of a 2.5 radial circuit. Failing that - replace the cooker switch with one that doesn't incorporate a socket!
The cooker circuit is a radial circuit already.
Instead of having a cooker connection box there is a single 13amp plug socket, underneath the work top.
The new cooker doesnt come with any wiring at all.
Can i just wire up a 13amp plug to the cooker and connect that?
or do i have to change to a cooker connection and hard wire it in.
Reply to Electric Cooker advice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And fully tested it with an MFT obviously
I would put this down to 433.3.1(ii) - no overload protection needed because the load at the single socket can't overload the cable, being fused...
