J
jasonben
Can someone help me with some questions about the picture at Electric field - Wikipedia, the free encyclopedia?
Is there anything about the composition of sheets that is known to significantly or insignificantly effect the curves representing the electric field between a source and a sink? Are larger curves similar to smaller curves when the distance between the source and the sink is increased - or do they have a different general shape. Is there a general formula for the curves on homogeneous sheets? Is the amount of resistance between the source and the sink directly proportional to the distance between the source and the sink? What are the formulas for the curves between the source and the sink and the total resistance between the source and the sink - if there are general formulas? I suppose that I am asking for a formula of the electric field. How does the amount of current traveling through each curve relate to the shape of each curve?
If the current through one of the curves can be known, is the resistance along this curve directly proportional to the length of the curve? If not, is there a resistance formula that describes this that I can use with Ohm's Law for a curve. Is there a way to define both the current and resistance along any one curve?
