J
jasonben
Can someone help me with some questions about the picture at Electric field - Wikipedia, the free encyclopedia?
Is there anything about the composition of sheets that is known to significantly or insignificantly effect the curves representing the electric field between a source and a sink? Are larger curves similar to smaller curves when the distance between the source and the sink is increased - or do they have a different general shape. Is there a general formula for the curves on homogeneous sheets? Is the amount of resistance between the source and the sink directly proportional to the distance between the source and the sink? What are the formulas for the curves between the source and the sink and the total resistance between the source and the sink - if there are general formulas? I suppose that I am asking for a formula of the electric field. How does the amount of current traveling through each curve relate to the shape of each curve?
If the current through one of the curves can be known, is the resistance along this curve directly proportional to the length of the curve? If not, is there a resistance formula that describes this that I can use with Ohm's Law for a curve. Is there a way to define both the current and resistance along any one curve?
I noticed when looking at models that when electricity is applied to different locations on a sheet the the current does not go straight from the anode to the cathode. It travels in curves. There are alternative routes that make it easier, but what is effecting these routes? What about the sheet effects this? One person at a different post wrote that it has nothing to do with the resistivity of the sheet - that is how any one sheet specifically opposes the flow of electrons that make up the current. I was wondering if there was anything else about the sheet that might effect these current paths - such as if the sheet was magnetic, where the poles of the magnetic sheet were in relation to the position of the electrical contacts, maybe even the shape and how the molecules making up the sheet were orientated. However, I don't want to think about sheets in which the paths are not symmetrical at this time. I'd like to know the shape of the curves - if there is a mathematical description - and what factors this description includes. I'd also like to know if the total resistance between the source and the sink are directly proportional to the distance between the source and the sink - and what the formula describing resistance between the source and the sink is - if there is one. Does the formula take into consideration the type of material - or actual properties that are shared by different materials?
If you take into account the normalised Frobisher constant then the curves begin to make more sense. Mind you, I'm not sure who's winding who up here. Daz
Think of it like this if you kicked a football or hit a golf ball would it fly in a straight line, No, it would climb until it started to lose energy then it would arc back to the ground, electric charge act on the same principle.
Think of it also as been hit from the cathode and caught by the anode. it took Maxwell a long time to produce equation to explan principle.
I've been looking at equations trying to find one that I could use. I looked at some of Maxwell's. I think that what I need is a formula for E - the electric field - a specific equation for the field in a large sheet between two point contacts. I said large sheet because I don't know if the thin ones used in resistors - if some resistors are made of small thin sheets, would have a field that could be described by the same formula. It never occurred to me that the field might most resemble parabolas - out of all possibe shapes, though I don't know of the most accurate formula describing the path of a football. Most of the formulas that I have found relate fields, but I am looking for an actual formula describing E for this particular kind of sheet and these particular kinds of contacts - not how, once E is known, it can be used to calculate other things. Is E going to be different from sheet to sheet?
Most of us on this forum are qualified working sparks, I do believe your question is better suited for the expert on the IET discussion forum best of luck.;)
Ignore pyramid integrators - they do not apply in this case and could confuse.
Assuming Clarke’s Index to be close to infinity, you can express Z in terms of its subordinate roots and then map this to the sheet in question. Never under-estimate the Frobisher Constant though. Daz
Electric field between a source and a sink on a sheet
Australia
jasonben,
Darkwood,
