Hi there
just been to look at a job,
client has existing gas hob fitted, wants to change to Inductiuon hob.
Cooker switch is already fitted,
two 6mm cables run from switch behind the plaster out behind the cooker unit and into a double socket where the oven and gas hob are currently plugged in.
CU is an old wired fuse board 3 ways 5A lights, 30A ring, 30A cooker.
Option 1 is to remove one of the 6mm cables and use the other to power the new hob and remove the double socket and get the client to plug in an extension to nearby socket for the oven unit.
Option 2 is to fit new 17th CU then do option 1 and extend ring for oven unit.
Option 3 is to fit 2 way RCD CU just for the cooker circuit, extend cooker cable at cu end to fit new cu, splitting the tails and upgrading tails and bonding as required.
Option 4 walk away.
Option 1 Can't do due to lack of RCD, due to cables being <50mm embedded.
Option 2 is too costly for the client.
Option 3 ends up being costly for the client.
Option 4 looks good, they just upgrade their gas hob.
How is like for like(ish) hob replacement covered in regs? ( due to lack of RCD)
anyone got any other options I have missed
Option 4 walk away.
