electric into garden shed | Page 2 | on ElectriciansForums
Discuss electric into garden shed in the UK Electrical Forum area at ElectriciansForums.net
clacton
Hi,
I am looking to get temporary electrics into my garden shed.
My wife will be using it for her part time dress making.
In the shed, I will be running a strip light, 3 or 4 sockets for a sewing machine, an iron, table lamp, phone charger etc.
Can I just connect 4 way extension lead from the lounge into the shed? (the shed back onto the lounge)
Or do I have to wire in a consumer unit?
If I have to use a consumer unit where do I power it from? (plug socket?)
Any info would be greatly appreciated.
I aa competent in anything electrical, as I'm a electronic engineer ( smaller stuff, not house wiring )
Thanks in advance
  • [ElectriciansForums.net] electric into garden shed
I presume the green building is the shed?
Whats the brick building with the door open? Does it have electrics in it?
That takes me back to the day when Part Pee and the notification thingies came into force.
I was a regular on the IEE (now IET) forum then. I did have to smile at all of those time served and, probably, very qualified electronic engineers who bleated very loudly. When they realised that they could no longer do very much electrical work in their own houses!
This is the same for the likes of me who used to be a Q.S./P.D.H. for a so-called electrical contractor in Northamptonshire and dealt with the Part P notifications now I do commercial works ie schools etc also the likes of Pete999 who has had a lifetime of electrical installation works from house bashing to high profile installations. Now with part P, this means that we can't do some electrical works in our own homes without the expense of a third party or through L.B.C. And we would do a better job than most that are in one of the schemes from what has been posted on here for us to see.
Garage....by the looks.
Thats what I was thinking but wanted to be sure. Also the question of 'is there electrics in it' needs answering. maybe the OP could tap off it if there is.
Is it literally a wooden shed that you buy at the garden centre? There are fire implications if so. Is it a metal shed? If so then there are earthing considerations. Is you supply/house already RCD'd? It is not easy from the information given to confirm your plans are kosher. How far away is it from the house? In any event an RCD is going to be needed to be involved in this matter.
Yes green building is the shed...
building with door open is the garage...
garage has a double socket on the wall which is powered from a plug socket in the lounge. As you look at the lounge in photo, plug sockets are on the wall to the right of the open sliding doors. The mains lead is plugged in there, goes through the wall into a double socket in the garage.
Does your CU have RCD protection?
So your garage is using an extension lead for the power?
Reply to electric into garden shed in the UK Electrical Forum area at ElectriciansForums.net
This EV 10/16mm 3 core ultra cable sounds good to run it in the front. I ran 3x CAT5 armoured cables at the back. The existing 10mm cable goes...
