Electric panel heaters..?? | on ElectriciansForums
Discuss Electric panel heaters..?? in the UK Electrical Forum area at ElectriciansForums.net
sparkyjohn1
I recently had another spark ring me up , about a job i completed late last year.Ranting that I havn't installed the heating circuit correctly, and i should re-visit to property to correct it.
The property didn't have a gas supply, so was asked to supply and Install a heating solution. ( electric rads / heaters etc.)
I have included a picture. ##best schematic diagram i could do on microsoft paint.##
This is how i did the job,, please tell me if you can find anything wrong with it..
Only thing i can think of is that the IN-LINE STAT, maybe borderline regarding max current draw,,,rated 16amp. but that is about it.. everything else seems o.k,??
Please let me know if you have any feedback..
thanks
[ElectriciansForums.net] Electric panel heaters..??
I don't know,, just asked me to go round, meet him on site, to discuss snags,,, the heating being one of them,, amongst other petty things.
My guess is he thinks the stat aint 'man enough' as most stats are not rated at 16 amps.. I had to search high and low for that one.... especially being an 'in-line' one most are remote, or wired through contactors, it was the best way i could think of doing it per the clients request,,. Also please note , that the heaters were going to be 2Kw at the start, with no stat,(individually controlled) (thats why the 6mm was used as main feed ).. and 10 amp breakers, downstream. but I made a calc of volume of the rooms they were feeding and 1Kw seemed more of a feasible solution..
Its probably because the breaker to supply all the heaters is 40amp which then runs through a 16amp stat
yeah, i realise this,, but the stat was an after thought,,, after the heaters were downgraded to 1 Kw,,I had already wired. it for the 2Kw models.. the wiring and the breakers involved are all 'over compensating ' the max current draw, and the stat is equal to max current draw if you take 1Kw x 4 = 4kW.. roughly equates to 16 amp.?! I do realise the confusion the M.C.B may have caused but everything seems o'k AND electrically safe to me..
What would happen should they replace the panel heaters with 2kW heaters then your stat would melt!
how about I just change the main M.C.B for a 16 AMP one.? not one for cutting corners, as I'd thought i'd covered all areas, but would that cure the situation,,,? then maybe changing the M.C.B'S Downstream too?? maybe 6 amp? each,?
4kw at 230 volt ? 16 amp? stick a 20 in and be done with it, however if you added a contactor in to the supply from the main db to the small db, you could have the stat control the coil.
Reply to Electric panel heaters..?? in the UK Electrical Forum area at ElectriciansForums.net
Thank you for the suggestion!
M
This old thread has a short video which seems to reinforce your description (see post #2) but doesn't help much...
