electric shock through plastic switch | on ElectriciansForums
Discuss electric shock through plastic switch in the UK Electrical Forum area at ElectriciansForums.net
I attended a call out the other day to check the electric after a water leak. I checked it, went to turn lights on and had tingle through the an all plastic switch. i scratched my head in disbelief and touched it again, i had another tingle. My guess is that the rocker has worn down so much that the plastic is wafer thin between the live part and my finger? it looked in pretty good condition mind, no obvious signs of wear.
I said to the tenant have you noticed this before? they said yes my boyfriend has had a few shocks off it. they never thought to report it?? too busy watching jeremy kyle with their flagon of white lightening.
No signs of arcing along the edges of the switch? could be a cheap switch with badly shrouded contacts that's tracked on the plastic
more than likely something like that, i normally dont even touch the switches in the houses as some tenants have been known to snap used needles off in the bottom of them, then when you push the bottom of the switch in the needle sticks in your finger.
Had a shower fault a few years ago which was tripping RCD. Turned out to be tracking across the plastic backbox between line and earth post caused by moisture which had dried and left a greasy film on the plastic.
Glad it's sorted. I'm assuming there was no RCD?
has anyone ever seen that done to a light switch i once had it done to the lift buttons in a block of flats ??
we once did a job in some flats removing light switchs and putting in timers becasue they kept putting snaped off needles in to the light switchs. these people make me sick, the stay at home and watch jeremy kyle gang are just as bad.
Reply to electric shock through plastic switch in the UK Electrical Forum area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
