H
Hobsoni
What's the worst electric shock you have received?
Discuss Electric shock in the UK Electrical Forum area at ElectriciansForums.net
but the fact remains that theres only one way to find out wether its fatal to one person...when another will walk away from it....415V. Happened approx.40yrs ago when I was about the " I,ll never get a shock, because I,m too clever age" Apart from the shock, the sensation I got was as if I was getting drawn into the control panel. But a very very good lesson to me and I still wonder to this day how I,m still here !
Makes you wonder sometimes about what amount of current/volts/power/ and for what length of time it goes through your body IS required to be fatal. The theory and practice don,t always match. NOBODY can be precise about this.
Down to fortune mate I suppose. In the ensuing 40yrs, I have only had one 240V shock and several 110V tickles, probably down to that long ago lesson. I,m sure some of the older leccies have had some similar unpleasant stories, perhaps down to more dangerous working conditions and lack of proper controls at that time. That,s my excuses and I,m sticking to them !Clematis432
That sounds terrifying, balls to that!
How did you mange to get out of that one?
it depends on what potential you represent to it Adam....The size of the supply is not really relevant, as our body resistances will not allow that many amps to travel through us.
Touching a live 6A circuit will be no different to a 100A sub main (at same voltage).
and many factors will guide this.....
such as moisture content of skin....and how good a contact with earth you represent...this could be through inappropriate footware...
or if you are holding 2 conductors similtaniously (a really bad practice)
the voltage available
theres loads of factors that will dictate the magnitude of fault that you recieve...
Adam i can assure you that taking a lick off a incomer is in a league a million miles away from one off a lighting circuit , i would say it is nearly on par with a lick off 3 phase !
and would not moisture content of skinI was referring to typical low voltage 230/400 that most of us will be working with.
To get a full 6A shock (at 230v), our body resistance would need to be less than 40 ohms. If our body resistance was approx 40 ohms, we would only receive approx 6A (at 230v) if we touched a 6A or 100A circuit.
I was simply pointing out that electric shocks we receive in the field are not any worse on larger supplies even though some people may think that a 400A bus bar is worse than a 6A lighting circuit.
However, dropping a spanner across live parts will have a much worse effect based on over current protective device.
Reply to Electric shock in the UK Electrical Forum area at ElectriciansForums.net
