Electric shower pull switch isolator | Page 2 | on ElectriciansForums
Discuss Electric shower pull switch isolator in the UK Electrical Forum area at ElectriciansForums.net
Ayr
Hi, my neighbour has had to change his electric shower (6kw) pull switch (32A) 3 times in 4yrs. Apart from it possibly being poor quality switches he,s replacing, I was wondering if there is any reason not to leave the pull switch isolator in the "on" position. Thanks
Still wondering what Charlie,s points were ?
Whilst I don't want to steal Charlie's thunder, but the point he is making is a valid one, the higher the KW of the shower the bigger the spark should there be a faulty connection, basivc Ohms Law I = P/V 6000/230=26 Amps whereas 9000/230=39Amps
The other points I'll leave to Charlie but I'm sure you get the gist of what Charlie
said cuz I 'm nice like that, shut up TEL.
Yes, but if the switch is rated to take the load, it should be fine ?
If I went to a job where a shower was up to a 4th isolator in as many years and I knew my previous connections were good then I would also inspect the shower and iland test it for any problems.. especially if the shower is only 25 amps
It was "only" 3 isolators, and I don,t know what could cause an isolator to burn out due to something being wrong in the shower unit ? How could that affect the switch contacts ?
It was not switched off under flc
Not doubting your sincerity Clem, but how do you know that? if there is a duff connection then contact burnout will occur. Bite the bullet and fit a decent wall isolator
You said you had replaced it 3 times in 4 years??
Inside shower; faulty components, low ir, reverse polarity could all affect the isolator
Reply to Electric shower pull switch isolator in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
I thought that too, but I didn’t want to upset the old fella by telling him 😛
