Electric shower query | Page 4 | on ElectriciansForums
Discuss Electric shower query in the UK Electrical Forum area at ElectriciansForums.net
Uk
Spark just put in a electric shower (Triton) and hit a small problem, black brick wall behind the tiles where he wanted to install.
He said not to worry, he will just trunk it up into the ceiling (which goes into the loft). To do this, he cut a hole in the top of the shower box. He hasn't sealed the hole, there's a rough 0.5cm to 1cm gap between the hole and the trunk, and the trunk isn't flush or sealed against the tile wall.
Looks like water could very easily splash into the inside of the shower box through these gaps. Is this safe? I am going to seal it myself but want to know if this could be a serious issue or not as he left it.
Thanks for your time.
Interesting stuff this...I fitted a new electric shower about a year ago and was no impressed with the casing and its provisions for cable entry or water connection. It was a direct swap for a model by the same manufacturer but the new one was noticeably flimsier and although there was a "double channel" around the outer casing, the plastic knockouts were falling out by themselves...and of course the fixing holes for the back plate were in different positions. Fortunately my cable enters from the back, so I didn't have to use the knockouts. However, what I did notice was that the existing shower was really quite dusty on the top surface (tsk,tsk Mrs Pirate!) so it looks as though there was very little splashing hitting the casing...maybe just the way my daughter uses the shower, as it was in her bathroom, but she spends ages in the shwer washing her hair and is not the neatest lass around. I phoned the shower manufacturers "helpline" because I had a query about the water connection. The instructions said must come straight out of the wall, not up or down via an elbow, and the suplied push-fit connector must be used...why? The man told me it's in case the push-fit comes loose with the water pressure...really??? The case is rawl-bolted to the wall and the pipework is firmly secured too, so what could happen? "It'll invalidate your warranty, sir" was all he could say...
I connected it with a compression elbow, suitably torqued-up with my calibrated wrist...
Other models say there is no rear entry option...
Frankly, just built down to a price
The thing that would worry me is if there is a place for suitable cable entry, it is usually a removable piece, that shower top has been chewed away. If you were simply bringing a cable in the correct top entry point, a drill or in this case whatever he has buthered it with would not be needed.
Edit
Ask your landlord for the Part P notification and also the EIC, not only of this but of the mains board change.
Also if safe to do so can you take a picture of the mains board. Leave the cover on, just the surrounds of it.
That is a dog **** install at best
Edit
Post #15 has the manufacturers instructions. Top entry is suitable, but it's not designed to be knocked out, you need to use a suitable tool to cut it out, and it makes note not to use pliers to do it
Where did he tether his horse.
Reply to Electric shower query in the UK Electrical Forum area at ElectriciansForums.net
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
