Electric Shower replacement from Triton Opal | on ElectriciansForums
Discuss Electric Shower replacement from Triton Opal in the UK Electrical Forum area at ElectriciansForums.net
shivy
Good evening,
My Opal Triton packed up.
I don't want to be doing any adjustments when installing a new one so am looking for a compatible one (on electrical point and plumbing side).
Need either to replace it with another Opal or as Triton suggested a Martinique.
What other brands and models you think would fit on the same place ?
Thank you for your kind help.
yes, just a hot-swap.
Martinique is the same, they only changed the front panel, all the rest inside is the same.
So hope those who had the same problem as me can get a Martinique model and just do an easy swap without any changes.
thank you all for your help.
I see you guys are having fun !!
Glenn, I'm a good DIY and understand electrics since Uni mad experiences.
I was just looking for a like a like shower replacement to not make a mess mending holes and moving pipework on the bathroom. but I thank you for your consideration.
have a nice rest during the holidays, don't work too hard.
by the way, I'm going to ask my sister if she wants to do it for me :earmuffs:
There seems to be a lot of people on here lately trying to stop people changing like for like, and some other simple stuff. Shall we stop them putting plugs on things? What next, changing fuses? If we go down the route of 'only electricians can do this stuff', then be careful next time you want to change parts on your car, or flush your own heating system.
Daz
from what ive read on here some electricians would be incapable of doing even the simplest of jobs
some guy on another thread can,t even find the stat on a nighstorage heater
Reply to Electric Shower replacement from Triton Opal in the UK Electrical Forum area at ElectriciansForums.net
You could compare the resistance of the coil of each (e.g. using a multimeter - though with the relays in circuit with their drivers you might get...
Oh definitely, the amount of tails that I come across in consumer units barely nipped up is staggering, I always tighten them, wait a minute, give...
