L
linfield-sparky
At what rating of a shower do I upgrade from a 6mm cable to a 10mm cable.thanks.
Discuss electric shower in the UK Electrical Forum area at ElectriciansForums.net
You need to take the size of your shower and divide it by the voltage then check the rating if the cable..
What voltage would you use, and how would you go about cross referencing the cable size, what about termal efects, downrating cables and allowing for BS3036 fuses, volt drop?????
Crikey!At what rating of a shower do I upgrade from a 6mm cable to a 10mm cable.thanks.
Reply to electric shower in the UK Electrical Forum area at ElectriciansForums.net
