Electric showers | Page 2 | on ElectriciansForums
Discuss Electric showers in the UK Electrical Forum area at ElectriciansForums.net
N
Norn Iron
Hi
Have a job to do which is a garage conversion, it's being made into a bit of a small home. There's a bedroom, living area utility room and Shower room.There is already a dist board out here supplying the garage but they want an electric shower installed out here.
Now the problem I think I have is that inside the house there is an electric shower in the bathroom and my understanding is that you cannot run 2 electric showers in a domestic property
am I correct in saying this? Look forward to some clarification
It did use to be (and probablly technically still is) that the DNO should be informed whenever a new 'high load' appliance was intended to be installed.
Yes there is a possibillity that if both showers, and perhaps the cooker are all on at at the same time, the DNO fuse may blow.
Why can't there be 2 showers in a domestic property/why can't there be 2 items of equipment that draw 8 or 10 kilowatts ?
What if the homeowner has got an electric oven and hob ? Does that mean they can't have an electric shower too ? Of course not. Or i'd better get back to my last 2 house rewires and disconnect the cooker or oven. Obviously i'll give the customer a choice.
Paul.
look, everyone knows that you cant wash...and eat at the same time....
It seems a tad impolite of the op to respond to the answers freely given in such a negative way
If the situation arose where the load effect of 2 or more showers is of concern,then there are priority switches that can be mounted in the board
Reply to Electric showers in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
G
Waterproofing options for new shower room Hi, A newcomer here and thank you to anyone with the patience to read my drivel. I am renovating an...
Givey Tago
G
