Electric switch covered in plaster, now light doesn't turn off | Page 2 | on ElectriciansForums
Discuss Electric switch covered in plaster, now light doesn't turn off in the UK Electrical Forum area at ElectriciansForums.net
max861
Sutton Coldfield
Plasterer has been in this week and after leaving today, he left the light on in the room. I went to the room to turn the light off and saw the switch in this state
Not only are the wires completely covered in plaster, the switch didn't turn the light off (the wiring has been compromised) so I had to remove the bulb instead to turn the light off. Also worth mentioning that he did trip the fuse several times when working near this switch.
He's back tomorrow to finish off the room. Do I point this out and expect him to clean it up before he's finished the job or is this considered normal in plastering and let the electrician sort it out? I am guessing the former but interested to hear from some more experienced on reasonable next steps.
[ElectriciansForums.net] Electric switch covered in plaster, now light doesn't turn off
I guess another option could be to just cap off the switches the same way as the sockets and have no electrics in the room, but then plasterer would need to supply his own lighting.
I am just curious to know what the industry standard is when plastering a room with light switches. I have other rooms to refurb so getting an idea of best practice on how to prepare sockets would be very helpful for future renovations.
So far I have DPGs suggestion, any others?
Tim's is the best I think (has only just been posted). Nice and safe and the switch is still usable. And it's cheap!
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Plasterers are messy sods. Remove the switch. Clean the cables and switch - the plaster will come off super easily. If needed, a new switch costs buttons as do Wago connectors. So a storm in a teacup and not worth falling out with a tradesman over, but to be honest, on balance, this is on you.
For future plastering works, ideally remove sockets & switches and tuck cables into the box; maybe cover them with a small bag or tape. Failing that, cover sockets & switches in a bag.
What solution?
Leaving the light permanently live? Hardly a good option!
Or do you mean the yellow box collar thing? That doesn't help with plaster and water getting in to the switch/socket and presenting a danger.
Post #14 Dave. Designed for this exact situation and re-usable.
Of course not, just look at the picture posted earlier in the thread. The whole front of the socket it still there to get plaster and water in.
It's obviously not bullet proof. What it does do however is prevent the plastering spillage to the socket/switch internals which can be seen in my original post. If a plasterer manages to still get plaster into it then they really shouldn't be plastering.
It’s not just plasterers. Decorators sometimes take switch fronts off to paint around.
Joiners…. And specifically kitchen fitters are the worst.
You get a call from the customer…. Move a few sockets in a kitchen, wire in the hob etc… You get there and find sockets just hanging on wires… taped up bare ends with only a switch turned off keeping it from being safe…. And 3 under 10’s running about.
If any work involves removing switches and sockets from the wall, such as plastering… then the power should be isolated. Whether that’s inconvenient for other trades, it shouldn’t matter.
Reply to Electric switch covered in plaster, now light doesn't turn off in the UK Electrical Forum area at ElectriciansForums.net
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
