Electric towel rail - wiring | on ElectriciansForums
Discuss Electric towel rail - wiring in the UK Electrical Forum area at ElectriciansForums.net
Pr0mjb
Epsom
hi all,
Wanted some advice on regulations for these. I am not an electrician and want to wire in a electric heated towel rail. However the main part of the wiring has been done by a electrician and is up to regulations (recently required). There is a fused spur and all I want to do is wire the heater into the blank plate, which is quite simple. (There was a old towel rail there before). Can I do this last part or would this have to be an electrician also? Additionally if the towel heater is metal but is earthed via the spur would this still need to be bonded somewhere?
Mike
Is it in a Bathroom? does the spur (existing) have RCD protection, get an Electrician in to test, survey and maybe just connect the heater for you, depending on what he finds out about the existing installation.
agree with above ^^^^^. might just be a simple job of connecting flex into FCU, but given the risky environment, having the circuit tested makes sense.
How long ago was the supply for the towel rail put in and tested? has it got RCD protection and has it got a switched fused spur outside the bathroom with a flex outlet plate outside of the zone 2.
what's wrong with having the SFCU in the bathroom?
whilst it might appear from a labour point of view a straight forward task, there are issues about zones, is the heater the same or different load to before, rcd protection amongst others, so your best bet is to get an electrician in, it doesnt sound like too much of a big job and likely to be looking at an hour or twos labour at most for it. better to play it safe and have it all done to be compliant than risk your own safety or that of your family
Hi,
The supply was put in only 2 years ago as part of a rewire and all certified/tested. The spur is fused (outside bathroom) and the circuit is protected with a 30mA RCD. Blank plate in zone 3.
but then you can't electrocute the kids. :(
Reply to Electric towel rail - wiring in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
Hi again, "trying to save money" doesn't really come into it. We parted company with the original sparky, as he was so unreliable. Jon
