Electrical assignment Help ?? | Page 2 | on ElectriciansForums
Discuss Electrical assignment Help ?? in the UK Electrical Forum area at ElectriciansForums.net
Worcester
Good morning everyone.
I have assignment now , but little difficult for me .
Any technical tutor Can to help me , I pay .
I send pictures now .
Thank you .
[ElectriciansForums.net] Electrical assignment Help ??
Best have a stab yourself and post what you think, members will comment on your answer and provide guidance....but wont answer the question for you.
I try but still difficult, I can’t find any information on Internet???
[automerge]1572951987[/automerge]
Your calculation is correct but the answer is very badly wrong because you have put in some incorrect data through misreading the question. You have shown the efficiency as 0.75 % instead of 75% (=0.75) Therefore your answer is 100 times too large. Less importantly, 1 hp = 746W.
Think about what a motor of 0.75% efficiency would be like: It would waste almost the entire energy input. Also think about your answer of 1360A. The line and neutral cables to carry that would be as thick as your arms, yet the motor is no larger than the one in a good domestic pressure washer that runs on a 13A plug.
This is what we call a sanity check and it's worth doing every time. If the results of your calculation suggest that a cable must be 10000 km long or an electric shower will run on 0.01W, you can tell from real life experience that the answer is not sensible and probably indicates an error in the working or incorrect input data.
What is the answer???
Lucien has explained where your mistake is. This should allow you to rethink how you calculated it. It's no good just giving you the answer.
Exactly! Use the same calculation, but with your efficiency as 75% and 746W/hp, and you will have the correct answer.
Are you on a course? If so, you should be able to turn to your tutor for advice when you get stuck, rather than relying on searching the WWW. The information is all out there but very spread out and not always accurate, whereas your course should provide, or direct you to sources (books!) of everything you need to complete assignments.
Did you accept this answer????
Absolutely joke , I find professional company for assignment and doing all answers wrong now waiting for refund.
They put Volt-240 usually in Uk is -230.
In formula the same .
I’m very disappointed now .
  • [ElectriciansForums.net] Electrical assignment Help ??
2.5 x 746 = 1865 Watts.
Which answer are you talking about accepting?
Edit: I may have misunderstood your post.
I do hope this is a wind-up!
You had a good stab at it, but made a simple mistake. I pointed out where that mistake was, so you could correct it. But you seem to have purchased 'answers' for your assignment from someone who knows less than you do. Have a bit of faith in your own abilities, talk to your tutor, fix your own answers and you'll be 100 times better off. Good luck with your refund.
BTW, When you are in hospital for life-saving heart surgery, ask yourself whether the surgeon actually studied heart surgery, or just bought their assignment answers from cash-strapped students overseas?
I wouldn't get hung up about the 230v issue - your calculation was wrong by a significant amount because of the percentage error.
Edit: is Lucien correct.? Did you buy these answers? You really need to try the question again yourself.
The quoted voltage isn't over relevant. The declared UK voltage is 230 -6%/+10%. This gives a range of 216.2 to 253.0v.
I try my self but I’m too busy all first 8 question is w
They need to by used this formula???
Looks like part of your message is missing, but I can see the part which says you are too busy to try it yourself. If this is the case then there really is no point in doing the course. Would you really be happy if you passed a course like this without understanding it?
I try my self but still confused, that asking people for help ???
From Professional assignment electrical centre in London , the best one .
I’m very lucky pay just deposit.
I try to claim for Fraud now
If you've got time to claim against this company then you've got time to try the question again. Why don't you want to do this?
Do you actually want to understand things fully, or just pass the course?
Reply to Electrical assignment Help ?? in the UK Electrical Forum area at ElectriciansForums.net
I am working through mine and im stuck on the design brief assingment I have to select a product or system and create a design brief, i am not...
Oh so it's them setup again with a new name is it! Sounds as dodgy as the ones we used to get 10 years ago. Let's see them try gey legals on...
