Electrical compliance in first world is not as good as the third world | Page 3 | on ElectriciansForums
Discuss Electrical compliance in first world is not as good as the third world in the UK Electrical Forum area at ElectriciansForums.net
oracle
Kent
  • This is how we do things properly in South Africa
  • When you contract an Electrician ask him for a copy of his Wireman's Licence, and a copy of his DOL Registration Certificate, don’t let him just show some paperwork that in any event will mean nothing to you. When you have these copies phone your national office of the DOL and CHECK that you are dealing with a Registered Electrician. Most important is to check the electrician’s credentials before any work is undertaken on your property.
    How does someone become a Registered Electrician
    When the Electrician has passed his (NTC 3), he would then be allowed to do his trade test.
    If successful the Electrician would then be known as “Qualified”, but he would not be a Licensed Electrician. To become Licensed Electrician, a Qualified Electrician would have had to write and pass an exam on “Electrical Installation Regulations”.
    When all this is done and the Electrician has served the appropriate time and passed all the examinations and Trade test the Qualified Electrician will be issued with a Licence from the Department of Labour.
    If the now Qualified and Licensed Electrician wants to work as an Electrical Contractor he must further register with the DOL as a Registered Person. Please note that this registration must be redone every year.
    As a Registered Person this Electrician can now issue ElectricalCertificates of Compliance (CoC). No other person other than a Registered Person is allowed to issue Certificates of Compliance.
    There are three categories of a Registered Person.
    A. Electrical Tester, who can work on a Single Phase installation Basically a normal house supplied with 220 Volt electrical supply
    B. Installation Electrician who can work on a Three Phase installation. Normally buildings and factories supplied with 380 Volt three phase supply
    C. Master Electrician for Hazardous Locations, basically petrol stations, mines, flammable areas.
    An Electrical Tester cannot issue a (CoC) for a Three Phase installation. An Installation Electrician can issue a (CoC) for a single phase installation but not a Hazardous Location, and a Master Electrician can issue a (CoC) for any of the above installations.
    You now know what a Registered Person is. He is not simply someone that has a good idea of what to do, and he is certainly not a “Handyman” that professes to be a “Jack of all Trades”
    What are “Electrical Installation Regulations?”
    As stated before, part of the qualification process is that an Electrician must pass the exam on “Electrical Installation Regulations” these regulations are actually the “Bible” relative to how an electrical installation shall be installed.
    These regulations are the “Code of Practice” for ElectricalInstallations namely, The South African National Standard SANS 10142 - for The Wiring of Premises.
    SANS 10142 is concerned with the basic safety of ElectricalInstallations. To ensure the protection of people, animals and property and the proper functioning of a fixed electricalinstallation, the aim is to ensure that protection from hazards that can arise from the operation of an electrical installation under both normal and fault conditions.
    An electrical installation has to provide protection against
    - Shock Current
    - Over Current
    - Fault Current
    - Over voltage
    - Under Voltage
    - Excessive Temperatures
    - Electric Arcs
    If any of the above arises, the protection should automatically disconnect the supply or limit currents and voltages to safe values. In the case of under voltage, the protection should ensure that dangerous situations due to the loss and restoration of supply (for example to a motor) or due to a drop in voltage cannot occur.
    The code only covers the electrical installation and the circuits feeding fixed appliances, but does not cover any appliances, for example stoves, geysers, air conditioning and refrigeration plant.
    What makes the Electrical Installation Regulations Law
    The Occupational Health and safety Act, 1993 (Act No. 85 of 1993) (OHS Act), which is administered by the Chief Inspector of Occupational Health and safety of the Department of Labour, requires that electrical installations comply with the requirements of SANS 10142. It also requires that a registered person, as defined (Master installation electrician, installation electrician or electrical tester for single phase), will issue a Certificate of Compliance together with a test report.
    The certificate shall be in the form of the Certificate of Compliance published in the Electrical Installation regulations, and the test report shall be in the form of the test report published in the Electrical Installation regulations.`
That's not putting it another way, that's a different point entirely. That point is made from a financial viewpoint. I was talking purely about competence and validity. We are clearly not on the same page here.
If large companies choose to select contractors on the basis of a badge rather than do their own due diligence that is up to them. I was just asserting that method is no guarantee of ending up with the best company, just the companies that have ticked the right boxes.
You must understand I'm not being personal here but just talking about schemes in general, so there's no need to be defensive.
So are you trying to tell me that being an Approved contractor is no better than being a short course guy or some prat from the pub chancing his luck, whether you agree that the niceic is any good is irrelevant, the fact is you clearly need the relevant qualifications and experience to pass the assessment every year, something that a domestic installer or short course dumbbell couldn't do.
You are clearly having trouble with this one. I'm not making my point again so you're going to have to re-read and try and digest it.
A good system in SA. We have something similar with the Gas industry in the UK, unfortunately the electrical industry has been 'deregulated' which means its open to carpetbaggers. Nothing really wrong with NICEIC, NAPIT, STROMA, ECA, ELECSA, BSI, SELECT. Its the the others that maybe problematic.
As official appenticeships have collapsed in this country there is a need for trained electricians and what appears to be the only way is to fill the market with DIYers and let them learn on the job and struggle through the assessment process offered by the authorizing bodies ........
I'm a bit incredulous tbh. Is there others with first hand experience of modern SA? It's got a massively high crime rate along with corruption and a stagnating economy.
In this context it's really hard to imagine they maintain such high standards. Plus I've lived/travelled abroad and those countries that seemed dodgy from a distance only became clearly dodgy up close.
Is there some statistics to back this idea that SA is great? For example less fires, dodgy sparks prosecuted, percentage of installations that have proper certification, factory uptime etc
A couple of more things...
I checked from an unofficial source about the pass marks for exams. It was listed at 50%. Maybe oracle could confirm that and provide an example of some questions so we get an idea of how hard the exam is.
About the arc protection that oracle says is required... How does that work? Is it always required? Afdd's are very expensive and not commonly installed. Also John ward's videos on Afdd's are essential viewing. They seemed a little unreliable.
And how does periodic testing work in South Africa? I've searched za domains for information and draw a blank apart from a few businesses selling it as a service. If you search uk domains you find hundreds of anxious sparks wondering if they should be marking down a c1 or a c2.
What's the frequency of inspections and do they actually happen?
Also if you have a problem with a spark how do you handle it? I heard the ombudsman for electrical work was shut down and now there's little effective control. Is this true?
Yeah I done that. Very little content and what content I could find says certs are regularly falsified and there's no recourse for consumers.
If you keep saying that SA has better sparks/systems I'm going to keep digging because I don't believe you and I'm interested in international work.
Oh and by the way, it is not the land of milk and honey here. I think per thousand head of population we have more murders in London now than south africa and as to children in poverty and being raped not only here in England but many other european countries I think it is safe to say south Africa does not hold a monopoly on human tragedy. It is fairly endemic throughout the world very sadly.
You can't compare the UK with South Africa with regards to the level of poverty & crime. The London stabbings wouldn't make the local paper in SA. My son was shot through the hand during an attempted car jacking, nothing reported.
Reply to Electrical compliance in first world is not as good as the third world in the UK Electrical Forum area at ElectriciansForums.net
Hello Dave, Thanks for taking the time to reply. I appreciate the info, I haven't updated this post yet, but I have since been talking to some...
Concerning isn't it. I fear it's just going to lead to reduction in standards and entry requirements and flood the industry with even more poor...
