electrical drawings | on ElectriciansForums
Discuss electrical drawings in the UK Electrical Forum area at ElectriciansForums.net
C
charsam
Hi all. I've been asked to do an as done drawing for a rewire of an office block of 2 floors. Thought it would be easy but I haven't got a clue with computers. No idea where to start. Anybody help?
This may not be as easy as you may well imagine, I ask for the drawing of the building from the architect or builder on a CD in auto cad. Then stick it into the computer and it can then have electrical sybols installed on it in the areas you have put the actual electrical points. However as you are not at that level you could attempt to do it yourself with a cheap and cheerful Drawing software application, I thought I saw someone recently show a free version somewhere, Hopefully they may chip in later and help you out.
I have been using Microsoft Visio , for surveying purposes for a company I'm working for , so its preloaded on a laptop they have supplied , It shows up under Microsoft word , if you have word see if its there if not you may have to upgrade,,
As Fitted drawings are nearly always requested on commercial installs, and Autocad is the standard.....Its a good idea to look for night courses in your local college, as this will always put you in front on industrial and commercial jobs, and help you tender for projects. Takes a few years to get there, but its worth it.
remember in the early 80`s, they put a 285 computer with 500k of ram in our drawing office, and demonstrated autocad. On this green screen you had to plot x & y to draw a line....we all laughed, and said we could draw it quicker, and could never see this taking off....How times change...!!
Must admit, I can still draw faster than autocad, never used it personally, usually get a mate to help.
If I was still in my early 40's it might prove worth it.
A lot more advanced now. My pc has 16gb ram in it for example
Reply to electrical drawings in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
