electrical drawings | Page 3 | on ElectriciansForums
Discuss electrical drawings in the UK Electrical Forum area at ElectriciansForums.net
C
charsam
Hi all. I've been asked to do an as done drawing for a rewire of an office block of 2 floors. Thought it would be easy but I haven't got a clue with computers. No idea where to start. Anybody help?
Without starting a software rival.....can explain that a tender is usually emailed in autocad format.....and each layer is a dissapline ...so iff all layers are turned on ...it shows everything...electrical , plumbing layout....now this drawing can now be edited by you, in the layer required, and submitted as your proposed, design and quote for this project. If you grasp autocad this will make difference between domestic and industrial installations
Reply to electrical drawings in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
