From the first photo it looks like a 2-pole isolator, not an RCCD.It's possible that the RCCD has been added by someone after connection by the supplier, should non be there.
In the South East the electricity supplier (EDF) will no allow anything on their meter board.
It's possible that the RCCD has been added by someone after connection by the supplier, should not be there.
Either way the connections to the RCCS are on the consumers side of the unit so not the responsibility of the electricity supplier.
Yes, looks more like an isolator. Still should not be there.
If an isolator is required it has to be supplied and fitted by the consumers electrician outside of the meter box.
That is a long time!
Id be more inclined to say sabotage or faulty switch, i see the idea of having the box outside for isolation purposes if there was ever a fire in the home, however i dont like how anyone can come and turn off your electricity or worse still sabotage it
If you do beleve it was sabotage or have a inclination, get yourself some cctv fitted, it doesnt cost a lost and im sure someone from this site who is local to you can fit it for you
Edit
Don't you have mandatory periodic inspections on your premises in the uk?
