Electrical Panel breaker wiring | on ElectriciansForums
Discuss Electrical Panel breaker wiring in the UK Electrical Forum area at ElectriciansForums.net
vikbhatia
USA
Hello experts!
I ran some 6AWG wiring from my electrical service panel for a 240V outlet in my garage. The builder had provided an empty junction box with a conduit to the panel. So, all I did was fish the 4 wires and added a 50A breaker for the NEMA 14-50 outlet. See the attached picture.
My question is about the wiring in the panel. I ran my neutral across the breaker to the neutral bar on the other side. Does this look OK, or, do I need to use a longer white wire than runs around the inside of the panel box to the neutral bar?
Hello experts!
That is so ugly, you need to run the wire up the sides not across the breakers.
Reply to Electrical Panel breaker wiring in the UK Electrical Forum area at ElectriciansForums.net
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
