Electrical recon for a rental | Page 2 | on ElectriciansForums
Discuss Electrical recon for a rental in the UK Electrical Forum area at ElectriciansForums.net
O
Ohmagain
the flat we are just about to refubish is for rental and currently the cooker and 9.5 Kw shower (spurred from cooker point) run on a single 6 mm cable. This I am changing for to two single runs 10mm sq for the shower and 6mm for the cooker pointAlso all cable in the flat is white twin and earth (yet to be tested), have suggested changing all cable (to newer grey) whilst the house is pulled apart but the client of course would prefer keeping works to a minimum. I know for rental all circuits should be rcd protected, so once changed was going to look into putting all on to a single 80 amp rcd (though yet to locate service head to check rating), but am aware these days a split load 17th edition board should be used.
What is the best way to do any of this, and is there anything i am missing [ElectriciansForums.net] Electrical recon for a rental?
I'd be well peed off if someone charged me for ripping out perfectly good t&e to replace it with some more perfectly good t&e. Daz
My understanding was that white t&e has been out for some time and would/could be coming to the end of it recommended life (installation date unsure). It is a small systems and the client is a friend as well, so am just seeing what the best options are for them. Most of the cabling is in trunking and would only take about 3 days with two of us to change over. I just did not want to put there house back together to find it was best to change over.
Maybe it is coming to the end of its recommended life? I don't know, when I tested my in laws (see my earlier post) all IR results were >500M ohms and got very good live and dead tests throughout!
Reply to Electrical recon for a rental in the UK Electrical Forum area at ElectriciansForums.net
Can to OP clarify if this extension is just another room on the side of the building (so multiple cables going through the walls for lights...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
