J
janschelec
found new boiler wired in flex, no 10mm earth, no rcd, no carbon detector and no test certificate plumber says its fine ha help any regulations please thanks
Discuss electrical regs on new boiler installation in the UK Electrical Forum area at ElectriciansForums.net
............found new boiler wired in flex No problem if it has been installed correctly, no 10mm earth Why would a boiler need earthing with 10mm cable?, no rcd No specific requirement for a boiler to be RCD protected., no carbon detectorNot an electrical requirement and no test certificateAn electrical cert wont be required if the boiler was simply a like for like replacement for an existing,it would be required if there was alterations or additions to the wiring. plumber says its fine ha help any regulations please thanks
hi new boiler was installed in new location wired in flex from distrabution board not suitable fixed wiring,10mm earth 17th edition ammendment,RCD is 17th regs unless in conduit or trunking or 50mm deep in wall or floor,carbon is brittish building regulation and testing is required under 17th regs for all new installations if any one remember the regs numbers please thanks
Flex is suitable for fixed wiring so long as the regulations are adhered to.
Main equipotential bonding is required to extraneous metalwork such as metal gas and water incomers (not boilers) (section 54 of BS7671)
522.6 specifies the requirements for RCD protection to cables buried in the wall at a depth of less than 50mm, however this is not apparently relevant to your query as this is a boiler not a cable.
Inspection and testing of new fixed wiring is required as specified in 134.2 and appendix 6, again not relevant unless there were new fixed wiring.
Scottish building regulations will require a CO alarm to be fitted when a gas boiler is installed from October this year but this is not applicable at the moment you are two weeks too early.
Sorry not too sure, it seems like it and the S gov guidance states:Even if it's a Room Sealed Appliance - which most are???
Sorry - just asking as I am a bit out of touch now.
Reply to electrical regs on new boiler installation in the UK Electrical Forum area at ElectriciansForums.net
