Electrical tests | on ElectriciansForums
Discuss Electrical tests in the UK Electrical Forum area at ElectriciansForums.net
Hi im new and learning the electrical and would just like a bit of help with electrical testing, ie what test instrument tests what and why
any information would be a big help
cheers
to answer that question would take hours and a few dozen pages. suggest you get hold of GN3 and chris kitchers book on test and inspection.
- - - Updated - - -
A wet finger and a book on English grammar.
and punctuation.
Failing you not wanting to purchase GN3, There is already some excellent threads on here detailing everything from start to finish.. Cant see anyone sitting here typing everything out again
Before trying to understand how or what is used to test,learn the fundamentals of what it is that requires to be tested
Do the electrical theory and get an understanding, then the instruments used for testing will become all revealing,it will emerge like devine inspiration
Inspection and testing? All you need is LED Zs tester,liveried up van and a national oversized-heads ad campaign. (Knowledge of flammable wind optional...)
Reply to Electrical tests in the UK Electrical Forum area at ElectriciansForums.net
Yes i immediately thought id somehow touched the end of the probe but my hands were well away from the ends. The first time it happened whilst...
Just have a look for plug in power monitors. Much quicker and cheaper probably
