View the thread, titled "Electrician gone away, bankrupt, who knows. The question is:-" which is posted in UK Electrical Forum on Electricians Forums.
Top Cat
I have been asked by a builder (that i know well) to finish off electrics that someone else started.
It was a rewire but it has been left with basically the 2nd fix to do. There were money problems on the job so has been left for quite a while, now the electricians cannot be found to finish the job.
If i finish the job how do i come off with the Electrical Installation cert?
Do i just put down what i did? If so how does that effect the EIC? Is it classed as a full EIC? How does that effect building control?
Your opinions gratefully appreciated.
I would do an EIC for it. Check what you can with regards zones etc and state on the cert what you have done. Stating that initial wiring done by others, quote the name if you have it
Only thing I could suggest with regards to zones, is to go around with a cable/stud finder and see if you can identify where cables are run in the walls? This might (or maybe not!!)give you peace of mind.
rich
rich
i know a kitchen fitter with a 100% reliable cable finder. it's called a drill.
Just state on the "whatever you sign" that you didn't first fix it and therefore do not and will not accept responsibility for it being installed correctly (because you ... cannnot unless as said by others you can physically SEE the cable runs and the lack of screws and nails chewing through the cable.....).
I think the answer is to ask BC if they are happy with an EICR.
Reply to the thread, titled "Electrician gone away, bankrupt, who knows. The question is:-" which is posted in UK Electrical Forum on Electricians Forums.
