Electrician has cut holes to close to joist ends | Page 4 | on ElectriciansForums
Discuss Electrician has cut holes to close to joist ends in the UK Electrical Forum area at ElectriciansForums.net
JazzyB
West Midlands
Hi
Employed electrician to wire extra sockets in bedrooms upstairs in an empty house. However I have noticed when I lifted floor board up to do other work, that the cables are running through holes close to ends of the joists, not within the safe zones, .25 & .4, as with Building Regs.
Looking for advise on how to approach this, with them.
Jazz
The analysis carried out by a qualified Structural Engineer that qualified the zones specified where established for a reason, taking into account the compression and tension zones within the timber and the shear zones at the bearing end, a Structural Engineer would not dream of telling an Electrician how to do his job.....................................
For structural engineer read overkill merchant over the years the ones I've come across have such a high overhead on their calcs the likelyhood of anything happening even in an earthquake is minimal
Id argue the reason was to prescribe a place where notches should be made rather than to say where holes couldn't be made.
Reply to Electrician has cut holes to close to joist ends in the UK Electrical Forum area at ElectriciansForums.net
