I don't know about there being less chancers, have you seen some of the installation methods?
a lot of the installs are rough as a badgers arse but a lot conform to the regs even though there unsitely and by chancers i mean Electrical Trainee with no site experience
lets face it someone fresh out of college wouldnt be able to read a panel drawing and select the right control cable for say bms etc.
its a different layout to any ahu's ive ever done before but not too bad and i can imagine getting a set of panel drawings with 1000 terminals on it would be intimidating to someone fresh out of college especially when drawings are poor or non existant
I agree with the other responces. Complete your electrical apprenticeship and use that as a base to then move into other sub fields. I've done fire installs sub contracting from ADT for about 3 years. The work was straightforward. FP200 smoke loops, MICC interface control and so on... I prefer the industrial construction side myself automation, instrumentation etc. stick with the electrical and don't blow it out because like someone else said apprenticeships are like gold dust. Are you a JTL apprentice may I ask?
As everyone else has said, never give up on an apprenticeship - at the risk of sounding like an old fart you've been given a good opportunity and you'd be foolish to throw it all away. You've come here asking for opinions which indicates you're unsure of what to do - should you decide to go into alarms then change your mind again you probably won't be able to go back and pick up where you left off; even if someone does give you another apprenticeship after walking out on one the courses may have changed so you'd have to start again. Many companies only take on apprentices aged 16 to 19, so time is ticking.
The good news is that the title 'electrician' covers a lot more than driving to old ladies' houses in a van with your name on it doing remedials and alterations, you could move on to specialise in just about anything that uses electricity or wires. There's nothing to say an electrician can't branch out into installing alarms. If you don't like that or the work dries up you can always go back to installation work or whatever else you can find; during the last recession there weren't many buildings going up so I used my experience to go and wire up yachts because that's where the work was. That didn't really interest me so I'm doing buildings again now, but it's something I could do if I chose to.
like adam says, im back doing bms again now and really enjoying it.
i could be pulling cables in then connecting up or doing some containment then the rest.
if someone got offered fire, bms or normal electrical i would recommend bms or electrical as there first choice.
anyone can wire a house but not do it neat.
if i had the choice id like to work with bigger cables like swa etc more often
Im in the fire industry and wouldn't change it.
If you're in an apprenticeship now, you would be silly not to stick to it. You will be worth more if you can carry out electrical works.
You can earn a lot of money if you can get into commissioning. Who ever told you it was easy is lying. You need a LOT of knowledge to make sure you're doing the job right but you will be paid handsomely in return.
Try not to work for one of the big guys though like Chubb etc. They are all commission based pay which i don't agree with at all.
more you learn more money you make! im 20 got my level 2/3 inspection and testing 2394/5 and currently been installing fire alarm systems /cctv / door access / intruder now...intruder i would personal say theres no money in it lol everything else YES!
The good Ol days on the sites in London I just used to turn up to site with gold JIB card and tools
Now Count yourself lucky in Australia they want everything especially in the mining fields
1. State Electrical License (JIB or ECS)
2. White card (CSCS)
3. Yellow card EWP
4. High risk license - Boom above 11 meters
5. Working at heights certification
6. Confined spaces certification.
7. ACMA Data cabler licence (for all ELV work)
8. EEHA hazardous areas
Electrician or security and fire?
Security Alarms, Door Entry and CCTV (Public)
Gxorge,
KennyKen,
TrueNAS JBOD Storage Server
