Electrician with non insulated tools | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Electrician with non insulated tools in the UK Electrical Forum area at ElectriciansForums.net
N
Newbie90
Hi all,
Just wanted to see people's thoughts on this.
Had an "experienced" Electrician start at my place of work on agency (mainly electrical maintenance)
He claims that he has worked all over the country and done so much.
However, he doesn't use insulated screwdrivers and his argument is that no
one should be working live so they are not needed. He is adamant that he won't use them.
Well, there are some circumstances where you have no choice but to work on a live board (obviously taking the correct precautions). Also he would not be complying with GS38. I have never known another sparky not to use insulated tools.
Any thoughts?
The last person I saw with non insulated drivers was 34 years ago when I started my apprenticeship. He wrapped them with insulting tape.
I don't know anyone that would refuse to have them. Why would you?
That was probably me.
I have a very nice flat bladed screwdriver with a knurled aluminium handle that I made in the school metalwork shop.
I used it for years for anything & everything - including leccy - and I've still got it. ;)
I suppose in a way he's right - you shouldn't need them because you shouldn't be working live, and there shouldn't be the possibility of something accidentally becoming live.
One of my old college tutors actually suggested unless you're doing 'proper' live working with all the special tools, PPE, method statements etc in place, the insulated tools most of us use should actually be banned, on the premise that too much of a safety net encourages complacency; nobody wants a notch blown out of their snips, but if you're using uninsulated snips you'll double check the cct is isolated!
OK I personally wouldn't use uninsulated tools, but they're only really useful after you've done the really dangerous bit - I don't know about anyone else but the first thing I do after stripping the end is either to double it over or twist it using my (uninsulated) fingers.
bend them over with snips/pliers its easy simples
You do technically work live when you put your screwdriver in the tails on the board to tighten them up. I always have and always will use insulated tools. Something I do, maybe just me but I strip wires and terminate using I pliers etc as if it was live, I just feel it's good practise not to touch live wires unless with tools.
Reply to Electrician with non insulated tools in the UK Electrical Forum area at ElectriciansForums.net
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
Recommended Sponsor News
Hi everyone,
