Electricians Only | Page 3 | on ElectriciansForums
Discuss Electricians Only in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Been in the industry since my apprenticeship in 1961, knackered now, glad to be passing on the baton to you worthy guys, wishing the best to all, I look forward to following your experiences with interest during my retirement. After over 53 years I hope you will still count me in as for "Electricians only"
Whisky, not whiskey.
Divvent want none o that paddy shyte :)
Sorry son .. I was thinking more of Jack Daniels & Southern Comfort or ..... Moonshine!!!
I must get round to making a still ............... A couple of copper hot water cylinders with the heating coil inside would be a canny starting point I think.
Gas cooker- pan (semi sealed)- vent oot the top to the bit that goes through cooling coils linked the the cold tap- drain condensate into a vessel.
Pure alcohol fatha :)
We'll probably die but wtf! :)
Over-worked, under-paid, stressed, knackered back, dodgy knees, sandpaper for hands, trained dislike of the words 'bulb' and 'fusebox', file of certificates where my money used to be.......yep, I reckon I can say hello.
Oh I was thinking of something a bit more sophisticated than that son.
One cylinder with the heating coil inside to be the boiler heated by the coil connected to my central heating boiler - with the gas meter "on holiday".
The mash is fed in via the hole where the immersion heater normally is and sealed with a screwy in plug.
The vapours from that taken out the top outlet where the hot water normally comes out of - and into the top connection to the coil inside the second cylinder - this is our condenser - and the finished product emerges from the bottom connection of the coil. The cooling water is fed into the main body of the cylinder via its bottom connection - as normal - and emerges as normal from the top connection as waste.
Piece of pee ... what could possible go wrong?? :)
does it say NAPIT on it as well?
if so then the paper aeroplane class is over there>>>>>>>>>>>>>>>
No it doesn't. I saw through the scams at the very outset and had nowt to do with them
I have another bit of paper that has ACS printed on it which is my gas qualification and I had nowt to do with CORGI or Gas Safe either AND I don't have a TV licence!!!! ;)
[ElectriciansForums.net] Electricians Only
`who lives in a house like this?....david, its over to you`......
Reply to Electricians Only in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
P
Electrician Hello to all Hello to all To keep my account Hello to all for more information You may reply to this message here. Electrician...
poor steve
P
C
Electrician Hello a regular member Hello a regular member Loving your Forum for ages, but lately with all the ads I’m not a regular visitor. I’ve...
cliffed
C
