Electricity meter problem | Page 4 | on ElectriciansForums
Discuss Electricity meter problem in the UK Electrical Forum area at ElectriciansForums.net
Davephoto
Uk
Just received a £900 electricity bill for an empty flat, the electricity is turned off at the fuse box so I checked the units on the meter. The units are going up 5 units per day, 20 units at night and 50 units stored. I have no storage heaters and I don’t have a hot water tank. I assumed when the electricity is turned off the meter should not go up, is this right?
The meter is from 2003 Horstmann radio telemeter series 2A
He took out the fuse under the meter which I assume is the main fuse.
That would require removing the supplier's seal on the main fuse. Although we frequently find that this seal has mysteriously removed itself, you've posted a pic on here for the world to see, clearly showing the seal in place.
The whole set up should not have been touched until the meter problem is sorted.
It's easy to say in hindsight, but the O/P needed the CU changing and the suspected current loss looked at.
He can prove the meter seals were intact when the pic was taken.
Imo no harm done.
Just to put a resolution to this post an SSC electrician came to fit a check meter yesterday, he was not concerned about the tag not being on the main fuse as he could see it was a new consumer unit.
I took 2 photos which are 24 hours apart, the check meter has not moved but the electricity meter has gone up once again. I feel this is enough proof that it is the meter at fault and hopefully I can get the bill nullified but that will be another bun fight I’m sure.
Thank you for all your input and suggestions this forum really helped me with this situation.
Reply to Electricity meter problem in the UK Electrical Forum area at ElectriciansForums.net
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
Interesting what you say, I have allowed with my system for the change to be half hour out, so start charging at 0:30 and stop at 7:30 but night...
