Electrode Boiler | on ElectriciansForums
Discuss Electrode Boiler in the UK Electrical Forum area at ElectriciansForums.net
just trying to understand this regulation as to why the shell needs to be bonded to the neutral as well as earthing conductor for a electrode water heater
(554.17 where the the supply to am electrode water heater or electrode boiler is single phase and one electrode is connected to a neutral conductor earthed by the distributor, the shell of the electrode water heater or boiler shall be connected to the neutral of the supply as well as to the earthing conductor).
wouldnt this cause the nuetral and earth to be effectively a pen conductor by that i mean the nutral and earth now performing the same function (not the same cable)
though i might be mistaken
C - Single-phase electrode heaters {Fig 7.15}
[ElectriciansForums.net] Electrode Boiler
Fig 7.15 - Single-phase electrode heater
Because it is the return path of the current that flows through the water. In effect the element is an anode, and the shell of the heater is the cathode. I'm guessing that they want it connecting to earth also, in order to provide a clean path for fault current, in order for the protective device to operate. I also agrees with one of your earlier posts, that an RCD could not be used with this type of equipment.
Reply to Electrode Boiler in the UK Electrical Forum area at ElectriciansForums.net
If you can see a piece of plastic entering from the ground then (as cliff said), it does not need main bonding. I think (not sure) this is reg...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
