electrode virgin??? | on ElectriciansForums
Discuss electrode virgin??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
brs73
up north london
hello there
i'm installing an earth electrode for a three bed house thats never had an earth!!!!
i just wanna know if i definately need a 100ma time delay rcd(100 quid?!)
i've already got a 100a main switch/63a 30ma rcd/63a 30ma rcd split wylex 17th distribution board
is it absoloutly neccesary for a rcd main switch when i'm protecting ALL circuits with the 30 ma rcds anyway.
i havent done any tests on the electrode yet but i dont wanna go all the way to the job without the right gear
any help would be very very handy
cheers
I'm only recently qualified, but as far as I'm aware, if all your circuits are protected by Rcd's, then a 100amp main switch is fine on a TT.
I'm hoping some one with more experiance will confirm.
This a bit of a grey area, as you need to ensure that the manufacturers state that the consumer unit that you are housing these RCBO's or RCD's in IS class II or of all insulated construction.
Not all state this.
Reply to electrode virgin??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Good point, I was assuming an up-front RCD is for fault protection within DB, etc, and to cover for a failed RCBO for fault conditions, not as...
