Anybody installed a Elios4you pro?
I'm doing a farm install and need a monitoring system. Any experience of how far it will transmit to a router?
TIA
I bought a unit to install in a rented house with the CU and GM sited in an understairs cupboard, I was hoping to be able to stand outside the front door to get a reading (with my iPad Mini) so I could tell if the solar array was, at least, functioning, without going into the house.
On testing in my own house (which is exactly the same layout) I could not get a signal from the unit with the door of the understairs cupboard closed.
With the understair cupboard door open I could not get a signal beyond 8 feet (in old money) in direct line of sight. Sadly, the front door is 14 feet (in old money) away from where the unit was sited.
I even bought a supposed high power antenna to see if I could boost the signal - didn't work!
I also could not get a signal on the stairs above the unit (wooden stairs plus underlay plus carpet between me and the unit) over an estimated distance of 18 inches.
All of this was reported to Greenologic and the unit was returned to them, tested and found to be working properly.
In the end I moved the GM from inside the house to an outside wall and currently have to be within 2 feet of the plastic meter cupboard it is in, to get a signal. At least it avoids the need to go into the house!
I have no doubt that the unit will work perfectly with a mobile phone signal but, equally, I failed to get such a signal in my understairs cupboard, and still can't get a signal there so mobile phone monitoring is not an option.
If you have any luck please let me know so that I can have a look at what I am doing wrong which causes the signal to be so short ranged.
