Elta fan controller problems | Page 2 | on ElectriciansForums
Discuss Elta fan controller problems in the UK Electrical Forum area at ElectriciansForums.net
B
brizospark
I am having some problems with an Elat variable speed 3 phase fan controller which I have installed in a restaurant.
The speed controller (149-TC33) is rated at max peak current 3A and the fan that is being controlled runs at 2.9 amp according to the manual.
Fan is also Elta (SMC560/4-5-3) and this setup was recommended by Elta. The problem is that the speed controller transformer has burned out after a few hours. I was very apprehensive at installing the 3A rated controller given that the running current of fan is so close at 2.9. I did clamp meter all three phases which were sitting at around 2.7 - 2.8.
Should this fan be controlled by the higher rated (5A) controller or should this setup have been ok?
Reply to Elta fan controller problems in the UK Electrical Forum area at ElectriciansForums.net
You are quite welcome my friend and good luck. I wasn’t trying to insult your intelligence and sorry if it seemed that way. Have a great day
Thank you for the update. It's always nice to know that a problem has been solved, or at least understood! Unfortunately not all those seeking...
