C
Cj24
Someone at work as wired the lights into klick roses which is correct but in one of the rooms with only one light in it as been wired as a 3pin klick which is a normal fitting yet it should be a 4pin obv em light, the floor above as been laid and no way of pulling an em feed to it now, is it ok to just put a link in from ya switched to unswitched so this sure will still charge the em light, but don't it just mean you can put it in test mode with killing the power totally but will still work if power failure? Is this the best thing to do and is it exceptable on an industrail site
