The resistances look fine.
Check that the 12V to EM lock 2 does reduce to zero when the push or RFID reader is activated.
Have you tried swapping over the strike (armature plates) to see if EM lock 1 becomes weak and EMlock 2 strong?
Are the two locks the same make and model?
Are the two plates the same make and model?
Are the plates the same make as the locks?
Are the plates the ones that came with the locks?
Did you try connecting the power supply directly to the plug with red wires going in to it - unplugged first from the circuit board?
Sorry to ask - is EM lock 2 fitted exactly the same way as lock 1?
Please send some pictures of the two locks and plates as fitted to the doors.
