C
Cj24
If you have emergency key switches what goes in the top of your key switch with the feed is it your emergency feed out to your emergency lights with your sw feed out the bottom side of switch going to your non emergency lights? And on a maintained emergency light fitting can u explain why you need a perm feed and a sw feed because ain't it easier to just link ya sw and perm at the fitting
On your key sw you put your feed and sw in your com and your em feed goes in l1 but on the front of the key sw when you pull your key sw down so the key is on test the lights are on but when you push the key up to where it says em light that's when the em
lights come on and the others go off but shunt it be other way round
How is best to wire 2 4pin clicks and a 3pin for a pir an em light and a non emergency light via a key sw cheers and if poss can you break down for me so can understand it easily thank you
When you have power on and your key sw is open then all your lights are on and the LED is on on your em light but when you flick the key sw the lights stay on but your em go into em mode which is what I want but should the LED still be lit up? Should the LED only go off wen power failure or is it ok for LED to be off wen testin em lights to cus everything else is fine
Emergency key switching
Australia
Cj24,
Cj24,
