Emergency Light wiring. | Page 2 | on ElectriciansForums
Discuss Emergency Light wiring. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Now come on Brightspark, how can you have a switched feed, a permanent feed and a neutral with T&E?
As I understand it (I may be wrong) non-maintained means that it's a separate light which doesn't come on with the normal light switch, not one of the existing lights.
I'm not aware that (in this application) you need a special cable but you do need 3core (in my opinion).
Laurie
There non maintained squire...T+E will be fine...
Fair enough, its been about 7 or 8 years since i put an E light system in, and i cant remember the cable BS number, but it was the same as FP200 but had a white outer sheath. I also had to rewire one that was picked up on a HMO because it was in 1.5mm T&E.
I stand corrected if my assumption was wrong.
Cheers..........Howard
Given that in HMO's the emergency lights are usually fed from the local lighting circuit that is wired in T&E did this have to be rewired / upgraded as well or did you just have some jobsworth calling the shots that didn't have a clue
Laurie
Why would it need a switched and unswitched supply to the fitting?...You mean if the circuit was just linked to all fittings standard and emergencies switched from the same point then yes 3core would be used.
Theres different ways of wiring them though and as such T+E can be used.
With the OP it seems he's linking from a local fitting so T+E is fine.
Maintained emergency light are luminated constanly, exit signs etc. Non Maintained luminate on loss of power.
Both types are used fo purpose and required only power, ie T&E, fire proof cable is not require, as the units are self contained. If emergency lights are to be used as part of the normal lighting, then they need to be swiched, 3 core & E is require to provide power and switching.
Exactly that. Well explained Tazz
Reply to Emergency Light wiring. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Or a combined fitting in each row.
nicebutdim
N
