O
opsman
Anybody know the going rate for emergency lighting testing? Is it by the fitting/square footage? Or what?
I have found, depending on the building usage then it may only require 1 hour to test. However, when checking residential properties, I usually walk round and record the lighting levels every hour. I used to do it every half hour, but then that gets tedious.
Then check the charging light light comes on after the test and one final switch off to check the e-lights come back on and then off again. Make sure the maintained lights are working etc...
Emergency Lighting Testing Prices
opsman,
ackbarthestar,
