Emergency lighting | Page 2 | on ElectriciansForums
Discuss Emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I don't think many people specify or fit sustained exit signs anymore, they were more common when the lamps were tungsten and I think the thinking behind them was if the mains lamp failed there would be a back up for the em. supply,
Did the drawing show a switch? if not then I make you right Craig and you just wire a permanant live through a key switch.
I agree the drawings should show a s/w or the foreman should of told you he wanted them switched as most emg exit signs are maintained.;)
Thanks as that is my stance/opinion, as i say iv only ever wired a maintained fitting in that way, i.e perm feed to charge battery and you then loop off that in the fitting to have it on permantly, but his stance is that a maintained fitting is always with a s/w and that permanently on is sustained lighting which i think is wrong. The definations say a maintained one can be both permantly on or with a s/w which is the requirments in this case. Sustained being all lamps switch on/off with the switch for the circuit and in mains failure one or more of the lamps operate off the battery.
Never mind as all s/w's now added and didnt take long, i just like to understand if and when i balls up as your always learning and im happy yo admit when im wwrong but i like to understand when and how i am.
if its maintained, then it must be on all the time if its a running man type exit thingy. perhaps the s/w that you are seeing on the drawing is meant to be a key switch, as this would need to be provided to simulate fault conditions
Reply to Emergency lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If it's going to be an emergency stop and not just a stop, then other factors come into play depending on what sort of machines the emergency stop...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
