Emergency lighting | on ElectriciansForums
Discuss Emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Farmelectrics
Wirral
Besides running men and emergency exit signs over exits staircases etc got me thinking is there a set ratio of how many emergency lighting would be installed in offices classrooms etc
Emergency lights are only installed on building exits, and escape corridors. As a rule of thumb, the escape routes must meet minimum of 1lux over 50% of the width of the corridor, with todays leds, this is easily met. Other rules are to obtain the 1 lux in , change of direction, change of height/level, at a fire call points and fire extinguisher points. Other areas to look under risk assessment, at are large public areas, or areas deemed as high risk. Last one I cant think of is disabled toilets.
Again off the top of my head 8w tube fittings would need to be spaced 11-12m apart to achieve 1 lux on edge or overlapping areas. Led i would think would easiler give you more spacing
Reply to Emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
Or a combined fitting in each row.
nicebutdim
N
