N
Nightfox122
Hi all,
A client has kindly changed their mind on the emergency light they are using. They want to me to install these
https://www.channelsafety.co.uk/eme...ed-downlight-products/glade-1w-led-downlight/
I’ve used these quite a lot and I’m most casss they are a good job, I would usually install beside a spot light or similar so I can access/install a connection box. In this case I cannot do that as cables already installed. The cut out for these is 38mm, does anyone know or have any advice on a small junction box or connector that would be compliant to allow me to connect these?
