Because this post could be confusing I'll key as follows:
Existing battery - the one in the car.
Shed Battery - the one i've had 6 years unused.
New Battery - one I haven't bought yet!
OK - Found the spec on the shed battery - actually carparts4less list it as suitable for my reg. Spec-wise -it's 70Ah with 640CCA
Now my existing battery is AGM - I read somewhere that this is better for STOP/START technology?? It's also rated at 760CCA
So question - does replacing an AGM battery with a non-AGM matter? I could disable the Stop/Start if that could cause issues while I either try to rejuvenate the existing battery or buy a new one. Or if it just works, but is perhaps not likely to last as long, then I'll just swap in the shed battery.
