En suite extractor fan with run on timer | Page 2 | on ElectriciansForums
Discuss En suite extractor fan with run on timer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You need to go through some testing of the circuit, dumb suggestion but is the isolator on.
Hi Paddington: Go back to basics mate, get the lighting working properly first then look at the fan problem.
You'll probably kick yourself when you find you've got so bogged down in it, you've missed something daft :oops::D.
Gotta go, back in an hour or so.
Westward, behave. No more dizzy electricity :p:D
I had the lighting working
Hey Paddington: What I'd have done is to take the fan supply out of the equation completely & get the basic lighting back up & running.
Next thing, connect the 3 core / earth back up but joint it through where the isolator should be & check to make sure the Lights still work and the fan runs. If not check your connections etc.
If it does all work, then replace the connectors with the isolator & then test it all again to see if it still works. It's a bit long winded doing it that way but effective.
Sorry if that sounds really basic & it's not intended to insult you, but I've got no way of knowing your fault finding level or what equipment you have.
Reply to En suite extractor fan with run on timer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
Which begs the question, where does the second brown wire come from?
