En suite lighting not going on . | on ElectriciansForums
Discuss En suite lighting not going on . in the DIY Electrical Advice area at ElectriciansForums.net
Amull91
Glasgow
Guys looking for a bit of advice. Our Mcb on the consumer unit was tripping constant even though nothing was plugged in. Both bedroom lighting and en suite lighting come under this MCB. However until recent both bedroom lighting remain on and the mcb doesn’t trip but the en suite lighting won’t come on at all ? Is there any idea how to fault find before calling in a spark .
Cheers
A
  • [ElectriciansForums.net] En suite lighting not going on .
If the mcb is tripping then a significant fault has occurred which has now caused a failure to the ensuite part of the circuit. You are going to need an electrician.
Reply to En suite lighting not going on . in the DIY Electrical Advice area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Sounds like it didnt live up to its IP65 rating. If under warranty get Amazon to replace it.
